RobFriedman
I have a LG G4 which has the currently-available version of Android 6.0.
When I plug in the phone to charge, it makes a sound. When it is fully charged, it does so as well. I would like to figure out how to shut off these sounds. Some research suggests:
But I do not see "Charging" in the settings. While I see "Sound and Notifications" I don't see "other sounds" listed when I go to that area. I think maybe LG has altered the functionality of Standard Android 6.0.
Does anyone know if one can shut off thee sound when one plugs in a LG L4? And shut off the sound when it is fully charged? If so, can you let me know how it is done?
Thanks.
You can switch off the 'charging sound' - search for charging in the settings or go to 'Sounds and Notifications -> Other Sounds'. This seems to switch off vibration as well for charging. This means you can leave vibrate on for (other) notifications.
Thanks.
