is there any indicator to know whether your phone is finished charging???
W werter14 Lurker May 26, 2011 1 0 May 26, 2011 #1 May 26, 2011 Add bookmark #1 is there any indicator to know whether your phone is finished charging???
R romedroid Lurker May 17, 2011 3 0 Jun 10, 2011 #2 Jun 10, 2011 Add bookmark #2 if u charge using usb, and indicator at the upper left corner indicates 100% and a short beep Upvote 0
J jaikrishna Newbie Mar 31, 2011 32 4 Jun 12, 2011 #3 Jun 12, 2011 Add bookmark #3 romedroid said it right. Although full charge happens only after 2-3 hours. Upvote 0
N nahna Lurker Jun 23, 2011 1 0 Jun 23, 2011 #4 Jun 23, 2011 Add bookmark #4 I have a problem .My phone's been charging for about 3-4hs, it's 100% but still charging, not charged. What should I do? Is the battery fully charged? Upvote 0
@ @ILE@ Newbie Jun 22, 2011 15 1 Jun 23, 2011 #5 Jun 23, 2011 Add bookmark #5 Leave it charging even though it is full. After a while it will tell you that it is fully charged Upvote 0
G glenn08123 Lurker Aug 8, 2011 1 0 Aug 8, 2011 #6 Aug 8, 2011 Add bookmark #6 How about when using a regular charger? Does the indicator still show?? thanks Upvote 0
suicidallooney Well-Known Member Jul 11, 2011 128 34 London, UK Aug 9, 2011 #7 Aug 9, 2011 Add bookmark #7 nahna said: I have a problem .My phone's been charging for about 3-4hs, it's 100% but still charging, not charged. What should I do? Is the battery fully charged? Click to expand... If your using the phone heavily like having a phone call or running cpu intense app, it will continue showing charging until you've stopped Upvote 0
