Help Charging this phone overseas?
Flowbee
I'm going to South America next month and know they have different plugs and voltage over there but wondering if I just need the plug adapter so it will fit into the wall outlets or will I also need to buy a voltage converter too? Is it made to be compatible? I don't want to fry it :confused:
South America includes several countries. Some use the same voltage & plugs as the US, some use the European versions of same.
Just looked at the "house" adapter that came with the phone and it says right on it 110-240v and 50-60Hz input, so all you'll need is an adapter for the plug. Info is printed right between the spades on the stock adapter.
