Chase Quick Deposit for Android???
Ferrari353
I just saw a commercial for Chase Quick Deposit (where they take a picture of the check to deposit it) and it was on an Android phone. How do I get this now? Right when I saw it, I went into market, but sadly, the Chase app had no updates...So it's not in the Chase app, it wasn't in a separate app (as far as I could tell), so where is it? Does anybody know anything about it?
When you log on, press the menu button and choose deposits. It will bring up a deposit screen and you choose which account, if you have more than one, you enter the amount and scroll down to take the pictures of the check. Works great and my wife loves it.
When did they come out with it? When I was at the bank a couple weeks ago, the banker told me they hadn't come out with an android version yet but they were working on it.
I think it only works on Android 2.2 and higher versions. I tried to use it today but it didnt let me deposit my check because checks have to be under 1000$. And you can't exceed more than 3 grands in a month. (sucks)
I've had it on my phone for over 1 month now, not sure when it came out but longer than 1 month ago. Also, I had it on the stock 2.1 before going to 2.3 so software doesn't stop you from getting it.
Oh I was looking in the market, and it talks about quick deposit in the JP Morgan Mobile app, not the Chase Mobile app...I now have both but both are currently unable to access my account or something...
I can't log in. When I try, it says it can't connect at this time or something like that. I've logged into the app before.
I was also having the problem where Deposit wasn't an option in the app. After being transferred up two or three levels on a tech support phone call, the person told me that something wasn't set right on my account. She fixed whatever it was and then it started working...
I used the Quick Deposit feature (Chase Bank) this morning and it worked without any problems. I just got back a confirmation email from Chase saying that they received and are processing the deposit.
Some time over the last month or 2 this software updated and now the check photo that used to use the whole length of my gs3 screen is much shorter. I can't see the check as well in this shorter window and I don't like it. Are other phones experiencing the same thing?
