Accessories Cheaper than BidAllies - 1500mah TP2 Battery
If you read through the auction carefully, it's written more like it's a battery that is compatible with HTC branded phones. I don't think this battery was manufactured by HTC.
It's described as an OEM. Either way, I might pick it up just to test it.
I got a red HTC 1500... It looked used, even though they said it was new. Emailed them and they still said it was new, just must have gotten beat up. My stock battery looks better! The 1500 had been worn on the edges...the edges had white on them and it was definitely used. Suffice to say, I am returning that and going for the BidAllies.
So just be warned!
