CheckSum Supreme [Tools]
5EihoBaFDfqHDaHwX96crmUZ2Mbvi9Kd9YhOPms2SVn4LvStgIR28uzH1XF5BtgFuQ=h310
oGAheyLFHb5rFsn5RW8W6gzFNMhdn_R0Xagd32-47TCWVhYHW0ci8trxDKj7G0_s8P0=h310
https://play.google.com/store/apps/details?id=com.microrev.checksumsupreme
CHECKSUM SUPREME (by Micro Revolution LLC) - A free, convenient, easy-to-use checksum software tool for Android. Get the checksums for files on your mobile device! Provides checksums for files using the following algorithms: MD5, SHA-1, SHA-256, SHA-384, SHA-512.
Check downloaded file checksums against the source checksum listings to determine a degree of authenticity for your downloaded files.
Distinguish similarly named files by their checksum! Now you will know if you have the correct version of a particular file by comparing checksums!
Copy checksum to system clipboard with a single button tap!
There are many uses for checksums, including those yet to be invented. What innovative use of checksums will you dream up? Now you have the tool to explore the possibilities.
Thank you, and Happy CheckSumming!! (I just made up that word):):D;)
