Chomp SMS
A month or 2 ago I downloaded Chomp SMS and was impressed so supported the developer and purchased a licence.
A couple days ago though I was having so killer issues with my phone could not be bothered to try and fix it so just did a factory reset on it.
Once I had done a factory reset I reinstalled Chomp and the ads were back so i tried clicking the support button under setting and all i get is this error
https://www.dropbox.com/s/ss1d1ldhhxp2jkw/2012-05-24 17.40.55.png
I have e-mailed the developer but still waiting for a reply was hoping someone on here would have some ideas as i hate ads with a passion.
It has to be the way you saved it. I rooted, reset and installed Cyanogen Mod 7 and got everything back, including paid version of Chomp.
Go back to Play and see what it says under installed. Reinstall from Play if it says Purchased.
Long story short it is fixed it was a my backup within chomp causing the issues. reinstalled the chomp app and set up manually now it is fine.
I could not reinstall the licence that was the problem I thought I had. It was a in app purchase, So It did not show up in googleplay and still don't to reinstall it.
All sorted now though
