ChompSMS 5.4 - Widgets disappeared
fried
I have a Desire running stock Android 2.2. I upgraded ChompSMS to 5.4 this morning and the widget on my home screen turned into an error message. I removed it so I could try and re-add it, but there's no ChompSMS widgets listed under Widgets any more. I hadn't moved the app to the microSD card (a new feature in this version of Chomp) so that's not the issue.
Anyone having the same problem, or know of a fix?
Hey.
You've perhaps already worked this out, but if you have moved chomp to the SD card, the widget will no longer work. Move it back to the phone storage and all should be apples....
