ChompSMS group messages
Clementine_3
¯\_(ツ)_/¯
I just started using ChompSMS and like it so far but I have a problem with group text/MMS that I can't seem to find a solution to. I get group messages sent from an iPhone (so, MMS) and if I reply then my reply shows once for each person in the group. If there are 5 people then my reply shows up in Chomp 5 times instead of just once? I'm guessing I have something set up wrong but don't see any setting in Chomp or stock messaging that would be causing this. It's makin' me nuts.
Also, I don't see a way to reply to just one person from the group message in Chomp. I can in the stock messaging but don't get that option in Chomp, is there a way to do it that I haven't discovered?
I want to like it and use it (hate the cartoon bubbles in stock!) but these 2 things are a tad annoying!
I too get a text from each recepient of a group msg. Not sure how to change it, but I like the other features enough to overlook it. Especially the ability to increase the fonts of outgoing and incoming messages. It helps these old eyes tremendously
I forgot to come back and update this. I sent an email to the dev's and they are aware of the issue and working on it. Hopefully it won't be too long 'til it's all fixed.
