I'm really not sure of your problem or why... have you checked the settings?
Otherwise, if you like Chomp, you may also like Handcent SMS as it has the same theme (iPhone theme) and other themes and also allows for voice to text as well.
I have the same problem. I can't send any text or received any text msg. And It will turn normal after few hour or days. I love chomp. I had tried handcent but I don't like it.
I had a problem with the stock messaging system. It turned out to be that my phone had deleted the 'Service Centre' number (Messages>Settings>SMS Settings>Service Centre). Always worth a check to see if a normal mobile number is there.. If nothings there, then there may be a problem.
