Apps Chosing Right Design Pattern
jklanka
I want to create an app and should choose a right development structure. app flow is
1. Firth Authenticate with Server using login screen
2. Periodically connect to Server and load REST Data ( each 3 minute )
3. Based on Data need to update the UI Screen
4. Also GPS Device Location Tracking Data ( Long, lat ) should be push to Server periodically, every 1 minute.
What is the best design pattern I will chooses for this. Are there any starter app for this.
Note : there are restrfit, rxJAva, http://androidkickstartr.com/, etc
Please advice
Thanks
Unlikely you will find a starter app that does all this. There may be sample apps that do some of what you want. Android Studio comes with sample apps, maybe check what's available and see if any are applicable to you?
