chrome bookmarks
nebler
Can the chrome mobile bookmarks be sorted into alphabetical order, resized or changed at all?
Cheers
From what I have experienced, it follows whatever arrangement you do on the Chrome for PC you have synced to it.
try the following instructions or you can sort them on your pc and then sync with your android phone
Code:
http://support.google.com/android/bin/answer.py?hl=en&answer=169021
Thanks, but still can't figure out how to put them in alphabetical order.....
Can it only be done on a PC?
