Help Chrome Home
  • Start date Start date
A
Android Question
Guest
When I close Chrome on my s7 edge then reopen chrome it goes to last page I was on, and not my preset home page??
How do I change this so it goes to my home page?
I don't use Chrome, but if there is no option in the app's settings my guess would be that if you close all tabs before closing the browser it will open on your home page next time you start it.
I don't see the above option in settings. But there may be several ways to skin the cat. Here's what comes to my mind:
You can create a shortcut that launches direct to your homepage.
Just go to your homepage in chrome. Then in chrome settings select "add to home screen".
Then click on that shortcut whenever you want to start chrome.​
Or you know, close the page you were last on. If you're pressing the home button to exit Chrome, that's not exiting. That's just minimizing the browser. Just the same as with if you or on a PC. If you click minimize, it's going to open back where you left and not a new tab.
