Chrome Questions
neil154
I have Chrome installed on my S3 and have a couple of issues.
1)Sometimes when I log on to a web site that requires a user ID and password Chrome does not remember the information (my settings are set to on for saving password).
2) When I am done with using Chrome is there a way to "exit" the app or do I just click on my home button to leave the app?
Sometimes whether or not chrome can save your password is determined by the website. For example, financial sites. It depends on the way the site is constructed.
You don't need to "close" chrome. Programs held in memory won't drain your battery unless they are actually in use. And don't use an app killer - you'll just be asking for trouble.
