Chrome to Dolphin Bookmarks help please
Ziani
Android Expert
Which is the best way? Been looking for a solution but many of the apps suggested are no longer available like 'Bookmarks to SD' Thanks
I've done it manually. But this thread at XDA shows several ways of going about it (nothing is easy as a straight sync, as in Google to whatever):
http://forum.xda-developers.com/showthread.php?t=1566596
Have a read there and then let us know your results. :) Perhaps others here will chime in.
If you haven't solved your problem yet you might use some unpolished work-around for to use the .html file with the bookmarks.
If you've moved the .html file with the bookmarks to the SD card of your new phone, try this line in the address field of your phone's internet browser ...
file:///sdcard/name of the file .html
... assuming that your .html file is in the root of SD card.
But you can put in any other folder path.
Your browser should work as HTML reader now and show you the bookmarks as a list of shortcuts.
Don't forget to bookmark it ;)
BTW, "file:///" also should work with files at your PC's internet browser ...
Harry
Why not just sync the bookmarks to the HTC default browser? If I remember correctly Dolphin has its own import from default browser function.
