Yes, I am. Also my CID is HTC_001 and how do I change that?
I'm using a Htc evo 3d(CDMA) and am currently on Hboot 1.57.5757 with s-off. Every time I get the PG86IMG file to the root of my SD card and reboot into bootloader to try to flash it I get a CID error.. I don't know what to do, can anyone please help me?!
What hboot/ROM are you trying to flash
This one should work
https://www.dropbox.com/s/19ovks154yqy640/PG86IMG_JBear_1.50.5050_hboot_GB.zip
Just make sure you're on a ROM that supports both hboots or you'll boot loop.
When you boot to recovery, you'll need to wipe everything and reboot recovery before flashing your new rom
Also it says my CID is incorrect so I can't update it.. my CID is HTC_001 and that's not the right one and I want to change my CID but I don't know how!
