Everything in this response is based on Motorola- Xoom - Family
First of all "Circle Launcher Problems" is a bit of a misstatement. I am extremely good at breaking programs. But this program is pretty solid, unless you try to push it over the top, which I do since I'm using it with Android Xoom.
To find gallery do the following
1. Selecting "Launcher Type = "Apps"
2. Selected apps = Gallery
To activate a circle launcher do the following:
1. Lightly touch circle (you will see launch tabs)
Note: If you do it wrong you may see a light square display over circle image. To correct this just hit or right arrow bottom, left of screen, one time.
2. Long hold and you will be in the "Circle Launcher".
On my PC XP or 2007 I will not use my PC without a program called "Opus", my utility lifeline for everything on my computer.
Circle Launcher holds this same distinction. it is just one fantastic launcher and I have tried them all, from "Go" to "No Go". When working in tandem with Folder Organizer I have total control of my Xoom.
Bob
