Hello,
I'm testing Citrix receiver (2.1.1078) with my Citrix farm (XenApp 5.0 with Web Interface 5.4 and Secure Gateway 3.2) on a Samsung Galaxy S2 (Android Gingerbread 2.3.3), everything works fine except I can't launch app...
Always the same error at launching app : "Invalid server certificate", when dismiss and continue :
"An error has occured while making an SSL connection to XenApp"
Self signed certificate (private) is installed on the Galaxy but it doesn't work...
By the way, no problem with Iphone and Citrix receiver.
Any solution ???
Do I have to export the private key ? (marked as unexportable...)
What is the certificate format understood by Android ? pfx/p12 ? pem/cer/crt ?
Do I have to root phone and play with cacert.bks to add my private cert ???
Thanks.
Any solution ???
Thanks.
