I removed CityID without making a backup after root(I know dumb), but I was able to find an .apk of it off the net to download but am still getting a
assert failed: apply_patch_check("/system/app/CityID.apk" error.
I am assuming its file permission error, if so, what are the file permissions supposed to be and how do I change them?
Or if there is a way I can goto a stock Droid X straight from the factory that would work as well. (I have tried doing the stock factory restore from the phone itself but it fails to re-install CityID).
Any help would be appreciated thank you.
