I bought a new class 10 Samsung 32gb MicroSD from Amazon (not a store on Amazon, but Amazon) and I've run SDTools tests and gotten class 10-like results. However, when I use USB Mass Storage I get a top transfer speed of about 1.5MB/s
I've tried SD Speed Increase, I've updated my drivers on my computer, I've tried different USB ports, I've tried different USB cables, I've tried flashing a different kernel (which resulted in a black screen, so I guess I don't know if this is a valid option), and I've tried the multi-mount app which didn't actually do anything (I clicked the widget repeatedly and nothing happened). I also tried connecting the card up through a USB adapter directly but it isn't recognized by my computer. MTP mode is nowhere to by found on AOKP, so I can't try it. On CM9 when I clicked it, it would just move back to Mass Storage when I plugged it in.
These are all of the fixes I have found while scouring the web for the last two days. My class 2 8gb that came with my phone went faster than this.
Phone info:
Evo 4G (supersonic)
Started this all out on JMZs CM9, but I heard CM9 had problems with transfer speeds, so now I'm running AOKP build 33 - All links to more recent supported version for my phone are dead (except Milestone 6, which isn't even supposed to be out for my phone, so I shied away from it).
My goal is to put roughly 20 gigs of music onto this card, and I will not wait for that to happen at 1MB/s. I thought of doing the transfer over WiFi but that seems like it'll be a PITA and probably not much faster because my internet speeds are pretty slow.
I made a thread on XDA but no one has offered any suggestions so I figured I'd try here as well.
Thanks in advance for your replies.
EDIT: This is a picture of the card info, can anyone tell me if it's just a fake Samsung card? It'd be lovely if that was the only problem
UPDATE: interesting discovery - If I go into recovery mode and enable USB MS I get speeds around 5MB/s
Phone info:
Evo 4G (supersonic)
