tacosdaddy
What's the best app to stop other apps from auto restarting? I've got the Clean Master (Cheetah Mobile) boost app that stops them with a tap, but they keep restarting. thanks
Putting to rest the myths about Task Killers/RAM Optimizers and the like
Clean Master will do a lot more harm to your phone's performance than good, and the company behind it are notorious data-thieves and spammers. Whatever else you do, delete that and any other Cheetah Mobile apps.
And the "keeping restarting" is part of why these things are worse than useless. Android works on Linux principles for managing RAM, and will keep previously or frequently used apps dormant in memory to save power (empty RAM is wasted RAM). Killing them just wastes energy, since the phone will dump them itself if it needs the RAM and otherwise they will most likely be reloaded after you kill them, all you are doing is confusing the OS's process management. If you have a rogue app then identify it and get rid of it, otherwise you genuinely will be better off leaving stuff alone.
And you'd need root privileges to do what you are actually asking.
ThankPutting to rest the myths about Task Killers/RAM Optimizers and the like
Thank youHadron is right. Please, read these:
http://forums.androidcentral.com/showthread.php?p=4655557
http://forums.androidcentral.com/showthread.php?p=5003350
Wow, I had wondered about that. Good thing I asked, and thanks for the quick reply. I recently uninstalled clean master and put DU cleaner on because the tablet was getting slow and the booster seemed to help. I left the apps on that the tablet came with because I was afraid of ruining something but I only downloaded a few others. Is there a better way to deal with the problem if the tablet slows down or are there preloaded apps that don't need to be there?
I have an asus memo tablet with Android 4.4.2. Halfway through reading Hadron's article I ran to get it and uninstalled all those apps. I had used them frequently. Have I done lasting damage to this thing?
Like I said, I'm new to this realm. What exactly constitutes bloatware and hat is necessary for the device to run properly. I don't use Facebook or most social media, but I do use google+ and play store.
so then I wonder when I will have to replace my tablet with a newer one. If it works fine now, how much longer can I expect it to?
