I got the same message when I installed the latest version of Clean Master. It was a much simpler app a year ago. Anyway, to get rid of that message, you'll need to install KS Security. So, I did that. And then, I realized I didn't need antivirus/security apps on my phone, so I deleted both apps.Yes i'm aware of how android works, however it was the SMS Vulnerability Fix that the app has that was my question.
The app does more that clean unused apps and wouldn't be using it for that anyway.
I guess the difference between the one available from Google Play Store and the pro version is no advertisments on the pro version.I got the same message when I installed the latest version of Clean Master. It was a much simpler app a year ago. Anyway, to get rid of that message, you'll need to install KS Security. So, I did that. And then, I realized I didn't need antivirus/security apps on my phone, so I deleted both apps.
I'm back to App Cache Cleaner Pro. Much simpler and it just clears cache.
