Clean up phonebook
Hi! ive been using wildfire s for a while, though it works very well, using the "phone" / phonebook is really annoying. ive been trying to google a fix but the phrases are too common to find any answers.
Problem nr.1 every time i open the phonebook, i get the dial pad blocking 80% of the screen (disappears after i start scrolling phonebook from that leftover 20%) how do i remove it showing up by default? its way faster for me just scrolling to the contact i need.
Problem nr.2 when ive opened the phonebook and got rid of the dialer, i first get a full call log/history and have to scroll all the way to the bottom to reach the usual contact list. this is really annoying, if i want the history, i can open it seperately, any chanse it can be disabled?
Problem nr.3 clicking on a contact just once will start a call... any chanse to make that into a double click or give it some kind of a confirmation popup? loads of times ive messed up with that...
i appreciate any kind of ideas to fix these issues!
cheers!
Well it seems you arent using the phonebook, you are using the phone app. If you just want to look and browse your contacts, you go to the people app.
