Help Cleaning bloatware
groston
I decided to clean some of the bloatware off of my rooted Pixel 3XL. The first bloatware I removed using ‘adb shell pm uninstall --user 0 <package>’ and there were no problems. However, it was pointed out that I should have TWRP installed in case something goes wrong. While I can do this, the phone is actively used and I am concerned about making a mistake. So, a bit more looking and I found something that suggested using ‘adb shell pm disable --user 0 <package>’.
The problem is that this didn’t work. When I tried ‘adb shell pm disable --user 0 com.verizon.obdm_permissions’, I got the error message ‘Security exception: Shell cannot change component state for com.verizon.obdm_permissions/null to 2’. Did some searching, but nothing indicated how to resolve this issue.
My question: Can 'pm disable' be used (and what should I do to avoid the error) or is ‘pm disable’ not a viable option for non-system bloatware?
You're using the old adb command which is unreliable. Try the new command instead.
Code:
adb shell pm disable-user --user 0 <package>
