CocodaMonkey
I've had my phone rooted for awhile but recently the battery life has been extremely bad (6 hours between charges) so I want to remove programs to see if it works any better. The problem I'm having is I can't remember which programs depend on each other and I'm afraid to remove something in the wrong order.
The only actual root program I'm running right now is SuperSU, Exposed framework/installer and busybox. If I want to remove Busybox and Exposed does it matter what order I do it in?
Also I'm still using Dalvik as my run time because I thought Busybox or Exposed didn't work with Art. Is that still true? Once I get it cleaned up I'd like to switch over to ART and see if that makes any difference before I start reinstalling the apps I actually want to use.
