I use a non-alcohol based computer screen wipey and a microfiber cloth for all of my cellphones.
Can you toss me some names please, thanks for the quick response btw!
Yes i keeps mines washed with tide and fabric softener
You should NEVER use fabric softener with microfiber. It doesn't matter if they are towels, cloths, mops, etc... The softener will ruin the microfiber. You should also refrain from washing it with cotton; the microfiber will hold onto the lint.
Wash all my microfiber stuff together as a small load on a gentle cycle with cold water.
