Clear android browser saved passwords automaticly on exit
kex007
Is there a way to automaticly clear android browser saved passwords on browser exit?
We are using mobile APN with proxy server - when user atarts android browser it asks for proxy username and password - I write credentials and all works fine. When I close browser (kill process too) and run it again - password is saved and browser dont asks for proxu credentials. Only way that I find is to clear saved passwords in browser settings.
One android tab will use many users and I want that every user logs in proxy with his username. Users would forget to clear passwords in browser settings and will work all the time with one password if browser dont clear the passwords automaticly.
Boat browser has a setting like that. Maybe you can deconstruct? It does clear passwords, but a user can change that setting.
Thank You for answear!
Boat browser do the same - when i check clear records on exit it clears history, not passwords - proxy password isn't cleared. password clears only after manual deleting of saved passwords!
In settings in Boat - there's one for remember passwords. On or off. Any browser seems to ship with everything enabled. It's under privacy settings.
This process act on normal internet browser also.Android use this concept but when we delete browsing history automatically pwd will be delete.
All works fine with forms of web pages but not not with proxy password. We can set "Dont remember passwords" in options of standart android browser - this option doesnt work for proxy password. I try to stop browser process, restart device - nothing works - next time i open browser it dont ask proxy login credentials - logs on automaticly. Only after manual deleting of passwords in browser settings or clear data of brpowser in Application settings. I can't find solution yet.
