Is there a way to clear the contents of the clipboard? Anytime I text (or text input), it thinks I'm trying to paste something and I have to tap it a few times to remove the paste feature.
Have you used the Application Manager, in the main settings menu, to clear cache in the apps you're inputting (sms, Gmail, etc)? Once that's done, and reboot of the device, start a new text then long press that input and a menu will appear offering, among other things, to clear the clipboard.
