cleared apn settings :( please help
cafonez
I think I made a boo boo ... :*(
I went into the data settings because i wanted to delete the metropcs proxy on the indulge and instead I reset the metropcs APN to default and cleared all the settings...
I still got an old optimus lying around I can read settings from to throw back on the indulge but im a little worried because i dont want to screw it up..
i now lost 4g because of my stupidity any and all help is appreciated
- so went back and clicked on restore in data settings
- it appears i got 1x...updated latest roaming list
- still had 1 x..updated prl to 3025.prl like i used to have before i screwed up
- still have 1x..but prl does show 3025..wait now getting 3g signal...
- shows support for lte in about phone
- worried... is there anything i need to do?
**FIXED**
Heres what I did..wiped all user data
Booted Basix - had errors - Force close screen on setup wizard
(tried to unsuccessfully boot several times in bootloop)
Re-installed basix through recovery menu
My speeds became higher but I am not sure if its just a newer rollout of LTE and maybe why my 4g was missing for a while?
I dl 3.3 mbps and upped 1.88 mbps (tested with speedtest)
several after the fact test show my unfortunate normal 4 g speeds 1.3 mbps and up around 1.2 mbps
