Clock Timer flawed?
gdhadden
So, on my LG G4, I could set the timer (in the clock app), turn off the display or use other apps, and the timer would ring at the right time. With my new V20, if I shut off the display, the timer stops. If I look at the timer app again, it'll continue counting down from the point that I left it.
Is there a setting that I should be using to get this to work right?
Thanks!
-geo
Don't have an answer on what might be wrong but my v20 works as you desire so maybe something is wrong. Try a battery pull.
