Help clockworkmod recovery fail to work
IAMGONE
Hello everyone I have a DROID X which is rooted 2.3.5 whenever I try to install cyranogenmod 9 and googleapps everything is going fine until it reboot,I get a message: Waiting for SD card to mount (20s )SD card mounted....
/tmp/recovery.log was copied to / sd card/clockworkmod/recovery.log. Please open Rom Manager to report the issue. CAN SOMEONE HELP ME THANK IN ADVANCE.
First you root your droid to 2.3.4.....ok
install View attachment 55886 (bootstrap recovery) to your droid then open bootstrap recovery
install cyanogenmod 9 from there
should be easy
