Root clockworkmod recovery for ace 2
Ecky
anyone know if cmr is available for the galaxy ace 2?
only been able to find references to cmr for the galaxy ace but didn't wanna try it without finding out if it was only for the ace and not the ace 2
I dont think you can install CWM using rom manager in Ace II, like you I've been searching the net about the compatibility. But all i can find is the temporary version of CWM for me temporary version is enough because i dont always use it :)
