Hi all. I need device firmware. Here are the characteristics that I can present:
Cpu: mt6735 (not mt6735m and mt6735p!!!)
full_tek6735_35_m0
Model: x23
Android: 6
something like that is not readily available. firmware are very device specific. you need to go to either your carrier or the phone's manufacturer to get firmware.
sorry then my friend......you are pretty much stuck with what you got. i would stay away from cheap chinese knockoffs as you will always run into this problem with them. plus who knows what spyware, adware and other malicious content has been added to them.
i would recommend that you go shopping for a new phone....preferably something that is not a clone of something else.
