closing by it's self ?
Hi
I'm having china clone ipad which have
android os 2.2
bulid number v1.3.1
I downloaded cut the rope for android and it works ( small screen like a mobile )
but when I tried to open the 1st stage the game close by it's self ??
what's the problem??
The problem is likely you have a China clone ipad. I also bought a tablet in China, and severely regret it now. Nothing is dependable, and many things just don't work correctly.
Go buy a real ipad, or better yet, a real Android tablet (not China version). Look for European or HK versions from reputable sources.
hmmmm thanks but I found a version that works on it the sound is normal but the motions are sloooow
is galaxy tab contain android or not ?? Is it better than apple ipad ??
If the motions are slow, it may be the hardware is underpowered (which is common on the cheaper Chinese versions).
Galaxy tab is what I bought. It's Android, but as I said, I'd look for an international version as a better bet. The P1000 has better processor and video specs than the P1010.
