Root CM 11 lg d320n
Status
Not open for further replies.
jeffta74
(Mod note - this has been replaced with an updated version - see other thread)
Cm11 d320n unofficial
1.CWM
2.wipe data/factory reset
3.wipe cashe partition
4.go too mounts and storage and open
5.format/system,format cache/format data and format data/data/media (sdcard)
6-dont format external_sd.
7.instal rom.gapps (im dont use gapps :) ) update super su
8.reboot and wait 5-6 m.
If you see a blue screen wait to settle down,if not, remove the battery
camera sometimes works sometimes does not work (go too camera setings and select external_sd.)
enjoy I tested two days works great except for a bug with the camera.
im fix bluetooth now working,
V.2 fix camera problem fix battery and more tweaks.
copy all three files to the sd.cm 11 d320n ,gapps,update super su.
http://www.4shared.com/rar/jpC1qLRgba/LG_d320n_cm_11_gapps__update_s.html
New version cm11 d320n
No more blue screens
Games working normally
https://www.dropbox.com/s/d2n3wy1up0lzzy2/cm-11-20141123-UNOFFICIAL- D320Nw5.zip?dl=0
final fix cm11 d320n
https://www.dropbox.com/s/gaoz3z9smpunzkd/CM 11 lg d320n Unofficial.zip?dl=0
cm 11 and the camera ,not a good combination.
on my hts one s with cm11 i installed google camera.
there's another bug to,after reboot apps dissapeare from homescreen (only apps on sd )
Works fine, bluetooth is fixed, never had issues with the camera however I have this bug where my hardware menu key acts like a secondary home key, and I can't rebind it, does anyone else have this issue on their d320 or is it just me?
How much storage does phone has with cyanogenmod because i have 200mb (didn't flashed it yet!)?
EDIT:
Does NFC work?
EDIT:
Does NFC work?
You get like 1.2-1.4 GB of free internal storage if you format data and system partitions before flashing the rom, sadly this rom doesn't currently have NFC support, not even a toggle.
Works perfectly, the only bug I noticed is that blue screen. Not sure with the battery (On blade g is draining 3x faster)...
EDIT
Found bug with display auto brightness...
Actually for me battery life is better then before. Unplugged it at 9pm yesterday, had WiFi on and used it until 12 am. Played FIFA for half an hour. Had WiFi on while I slept and battery is 48% now. Have been using WiFi for an hour or so. Haven't plugged it in since yrsterday.
My battery was about 80% when i was about to flash a rom and that was about 7 pm and at 11 pm (with cm) battery was 37% idk is it because of flashing or something else but ill see how it goes...
EDIT
Lags as hell at start...
No idea. Although my l70 is d325 and not d320n. Coincedently now it also charges faster.
Try this, completely use up your battery until 0. Let it charge until 80% or over. Then turn it on. Also check settings->performance and see that profile is balanced. In processor governer is on demand and io scheduler is cfq.
Status
