Root CM 12 Beta For VM GS5?
Will you try stock? tell me if it works on both send and receive, sadly, this was a big issue for the S3, which we had fixes for. So that way i know which way to head with it.
Just tried it. It works but its a bit buggy on stock messaging(takes a while to download and force closes sometimes.) Google messenger would be what I recommend though as its basically the same design. Hangouts is flawless as well in terms of functionality. Hope this helps!
There's a Google messenger now? lol didn't know that. I just got my phone today, im waiting on my SD card to arrive so i can root and back-up and all that good stuff. is it pretty stable?
Haha Yup. I love the app. Very stable. Congrats on your new phone, man!
Do you know if there's a full sub thread for VM galaxy S5?
No dedicated full subthread. Posting in the Sprint section is probably good since most all things compatible with sprint are compatible with VM, as they have the same model # and software.
There was this thread (http://androidforums.com/threads/sm-g900p-find-a-link-to-what-you-need-here.850449/page-5) for boost mobile, but also for VM. The OP seems to be not updated anymore but you might get some help there as well. Also good for getting links to backups in case of emergency.
Hope this helped.
