Root CM 6.1 Home icon help
I will try to explain this. So I wanted to get rid of a icon so I did the following: I dragged the icon to where in CM 6.0 would be the trash to remove it. However, with 6.1 the remove/trash is up top. So what ended up happening is the icon I wanted to remove has replaced the icon that takes me to my apps. I can not for the life of me figure out how to fix this. Help?
Long press on the home screen to add a shortcut. Select custom shortcut. Select pick activity. Select adw launcher actions. Select open/close app drawer. Then simply drag it to where you want it on the launcher.
