Root CM 7.2 MMS Fix?
xFznX
Member
Can anyone help give directions on how to get Data/MMS working on Reqs CM 7? Been searching all night but can't find exact directions to get it working. Thanks!
Edit: actually got it working once I posted this. Haha!!
ypu thats how its fix for the CM7.2-RC1... theres two other available build, so dont get them confused. CM7.2-RC2, the latest Cyanogenmod 7 Port. just to clear out the confusion, they are all made by Requisite0 or AquerMang, as he goes now.
This is the one where you can pretty much get everything working, but data and wifi can be unresponisive and its buggy.
http://androidforums.com/admire-all...om-cwm-kernel-cm7-2-rc1-requisite0-beta2.html
Another build, one that i was a never able to boot but other members had better luck on it
http://androidforums.com/admire-all...equisite0-beta-cwm-cache-issue-addressed.html
And the latest more promising build that is the most stable but still needs work
http://androidforums.com/admire-all-things-root/724430-cm-cyanogenmod-7-port.html
Thank You i appreciate your reply.! Ima give a run now, all i truly need now is the camera button fixed...
