andriodadmirer
CM10.1 JELLYBEAN 4.2.2 FOR E739 (O.D.rom)
for the E739 LG MY TOUCH
THIS IS JELLY BEAN 4.2.2
what's in it?
1. I REPLACED 4.2.2 CYANOGENMOD BOOT ANIMATION WITH KITKAT 4.4.4 CM ANIMATION
2. REPLACED CM FILE MANAGER WITH OMNIROM 4.4.4 "SIMPLE" FILE MANAGER
3. ENABLED NAVBAR AND SHORTENED THE NAVBAR HEIGHT SO AS TO NOT INTERUPT THE KEYBOARD POPUP OR ANY OTHER U.I.
4. *****PIE IS ALREADY INCLUDED IN CM10.1 FOR MOST PHONES AND OURS IS ONE OF THEM
TO ENABLE PIE CONTROLS YOU HAVE TO GOTO SETTINGS/SYSTEM AND
ENABLE EXPANDED DESKTOP THEN PUSH POWER BUTTON TO REVEAL
POWER MENU AND SELECT TO ENABLE EXPANDED DESKTOP FROM THERE
AS WELL ONCE THIS HAPPENS THEN YOU GOTO SETTINGS/SYSTEM AGAIN
SCROLL TO THE BOTTOM AND YOU WILL SEE "PIE CONTROLS"GO INTO IT AND SET IT THE WAY YOU LIKE AND YOU NOW HAVE PIE
5. I INTERGRATED AN APP CALLED LOOPR INTO THE SETTINGS
THIS APP IS A MULTITASKING APP VERY SIMILAR TO PIE CONTROLS
(SWIPE FROM THE SIDE OF PHONE TO REVEAL THE APP "ARC"
THE REASON I USED THIS APP IS BECAUSE IT HAS A FEW SPEACIAL FEATURES WHICH ALLOW YOU TO OPEN UP ANY APP IN THE HALO WINDOW,I FIND THIS VERY HANDY AT TIMES.
JUST FOLLOW ALL THE PROMPTS OF THE APP AND MAKE SURE YOU TICK ANY REFERANCES TO USING THE APP WITH THE HALO WINDOW.
6. I INTERGRATED THE LATEST XPOSED FRAMEWORK APP SEEING AS HOW THIS IS ALMOST A MUST HAVE APP FOR MOST OF US.
TO USE XPOSED YOU HAVE TO FIRST INSTALL THE framework SO...
A.ENTER THE APP
B. SELECT INSTALL FRAMEWORK
C. WHEN DONE INSTALLING YOU NEED TO REBOOT YOUR PHONE SO THAT XPOSED BECOMES ACTIVATED
7.I INTERGRATED 2 XPOSED MODULES INTO SETTINGS AS WELL
1. XUIMOD=A COLLECTION OF MODS FROM DIFFERENT AFTERMARKET FIRMWARES
ALOT OF DIFFERENT ANIMATION MODS, SOME
CLOCK,LOCKSCREEN,SCROLLING AND OTHERS
2. XHALOFLOATING WINDOW MODULE
THIS IS OF COURSE THE FLOATING POPUP WINDOW WITH MULTIWINDOW FEATURES AS WELL
THE WAY TO ACTIVATE THESE APPS IS TO
GO INTO XPOSED APP
GOTO MODULES AND SELECT IT
ONCE INSIDE THE MODULES SETTING YOU WILL SEE THE 2 MODULES I INTERGRATED
ALL YOU HAVE TO DO IS TICK BOTH OF THEM AND REBOOT AFTER
REBOOT THE APPS ARE NOW ACTIVE YOU GET TO THEM THROUGH THE
SETTINGS AND ARRANGE THEM HOW EVER YOU LIKE AND THERE YOU GO
8. I CHANGED THE RO.SF.LCD_DENSITY=200 INSTEAD OF 270
9. I ENABLED DUAL PANE MODE IN FRAMEWORK (THIS IS WHY SETTINGS IS DUAL SIDED )PRETTY MUCH TABLET MODE
INSTALATION
1. BOOT INTO CWM
2. WIPE DATA AND CACHE
3 GOTO MOUNTS AND STORAGE AND FORMAT SYSTEM,DATA AND CACHE
4. GOTO ADVANCED AND WIPE DALVIC CACHE
5. GOTO INSTALL FROM SD AND FIND THE ROM.ZIP
SELECT YES TO INSTALL
6. AFTER INSTALL SELECT REBOOT SYSTEM NOW AND THERE YOU GO
HERE IS THE ROM LINK
https://www.mediafire.com/?ld14j1ep7qsqh7m
what's in it?
A.ENTER THE APP
GO INTO XPOSED APP
INSTALATION
1. BOOT INTO CWM
