Root Cm10 For/Against ?
I prefer aokp just for the fact of more customization even though it's cm based.
I won't be running it as my daily driver until they get all the hugs worked out. But they're really close.
The 10/9 and newer builds only work with safestrap 3, which isn't out yet but it's coming soon.
Idk man I don't have gsm. Buy there are plenty of bugs with any of those. They aren't ready for an official release. I suggest you go to droidrazr.com and look at roms for your phone before you do anything.
Also make sure you can follow directions and actually read them all before trying anything as you can really screwed stuff up if you don't do it just right.
will do thanks for the headsup
all 4.1 roms arnt exactly perfected yet but they are useable. From what i believe, the gsm phones are having better development results.
