Background: I decided to use @vm03 's sources for the LG L70 (https://github.com/vm03) to build the latest CM12.1 for the L70. I then Bumped the boot image for our locked bootloader and removed lines for the L70 (w5) from the updater-script in the resulting zip file...
...And CM booted!
UPDATE (11/21/2015):
We now have a semi-working CM12.1 ROM!
Updated package:
https://www.androidfilehost.com/?fid=24269982087000841
Updated boot image - solves problems 1 & 2 in this post:
boot.img: https://www.androidfilehost.com/?fid=24269982087002191
UPDATE (11/24/2015):
New kernel/boot image with SELinux set to Permissive:
https://www.androidfilehost.com/?fid=24269982087003853
*As always, flash at your own risk!
*Take a nandroid backup before flashing (you're gonna need it ;-)
*This ROM is still very much a WIP, but we're getting there!
SOURCES:
...And CM booted!
Updated package:
- This ROM requires you to flash a keylayout fix - see this post
SOURCES:
- Device Tree: https://github.com/elisam98/android_device_lge_w5c
- Vendor Blobs: https://github.com/elisam98/proprietary_vendor_lge_w5c
- Kernel Source: https://github.com/elisam98/android_kernel_lge_msm8610
- Local Manifest: https://github.com/elisam98/android_local_manifest
