Root CM12.1 Unofficial Beta
Bad_MOFO_33
:specsdroid:Hey guys, sorry for the wait.
Newly compiled CM12 Unofficial Beta for Lg Volt (LS740)
I take no responsibility for any bricks or anything you do or don't do to your device!
Most things work but some things don't. You must remember Cyanogenmod12 is still Beta, and updated constantly. Meaning that something that works in a particular build, may not work in the next.
Still some bugs.... major one being LTE/4g
As Always be sure to have a BACKUP!!!
Not sure what fully works and what doesn't. Feedback welcome.
Thanks to all of our devs for our device. And thanks to our community, you guys are awesome.
ENJOY!:thumbsupdroid:
Anyhow here you go...
Update 6/08/2015:
https://www.androidfilehost.com/?fid=24052804347757588
Update 6/28/2015
https://www.androidfilehost.com/?fid=24052804347766319
Fixed Video Playback mostly...
Vine, Snapchat, and Netflix should be working
Updated Vendor trees to include some DRM stuff
LTE should be a little more stable
Used same trees for Blisspop
Set SElinux to permissive by default
Update 9-20-2015 : https://www.androidfilehost.com/?fid=24052804347819551
LTE/Data connection improved
Latest Nightlies
Update 3-29-2016 : https://www.androidfilehost.com/?fid=24459283995308491
I know its been a while. But decided to update with latest nightlies and @ShapeShifter499 OTG commit
I havent personally tested anything, just made sure necessity things work like booting, adb, mtp, sound, charging.
anyway hope you like it...
TWRP 2.8.7 Recovery: https://www.androidfilehost.com/?fid=24052804347771339
Twrp to 3.0.0 with USB OTG support http://androidforums.com/threads/twrp-recovery-3-0-0.1014613/
Wiping is a lot faster now.
MTP and ADB both work
Flash ROM
Boot
Reboot to recovery
Flash Gapps
Flash APN fix
Reboot
Change SElinux to permissive mode( use kernel auditor or SElinux mode changer)
Pick APN of choice
Reboot
LTE problems should be gone
GAPPS: https://docs.google.com/document/d/1_MVA7YAp3uVYzv33hXzRJZY3kGCTJgVsO727bD6qreg/edit?pli=1
VirginMobile APN Fix: http://androidforums.com/threads/mod-universal-lte-virgin-mobile-apn-fix-wip-cm-aosp-4-4-x.840298/
Boost APN Fix: http://androidforums.com/threads/mod-universal-boost-apn-fix-for-d2lte-builds-mod.840501/
Sprint APN Fix: http://forum.xda-developers.com/google-nexus-5/general/fix-sprint-data-to-custom-roms-t2541924
Camera fix for now : https://play.google.com/store/apps/details?id=com.sumoing.camu&hl=en
Ringplus APN Fix: http://androidforums.com/threads/cm12-1-unofficial-beta.905257/page-66#post-7000962
Deep Sleep fix: http://forum.xda-developers.com/g2-mini/development/deep-sleep-fix-cm12-t3020479
IRC channel ##lg_volt on freenode
https://plus.google.com/u/0/communities/102821577590068234569
Updated Sources 5/28/2015
frameworks_base_data_keyboards is fix for back and menu key vibration
@Bad_MOFO_33 I'm using it now and this is nothing short of amazing! 3g works perfect, I don't use 4g because of my data plan but I can try that too. WiFi,sound,GPS,calling and sms works via hangouts for me and youtube etc too but the setup was super easy and let me choose what apps to install intially. I enabled root in the dev options and that works great. I'm itching to try xposed so I'll see how that works but props to you and @invaderjohn this is awesome! Thank you so much for all of your hard work! I snapped a few pics so peeps can see what it looks like :) cheers!
just a note, I flashed the xposed lollipop alpha and experienced the system storage running out error and google play services crash. It may work for others but I am going to wait before trying xposed again
Looks great, tried it, smooth, but couldn't find ART runtime in developer options. Bad_MOFO_33, InvaderJohn doesn't believe in overclocking (read it in his thread), so could you please use attached OC CPU config in your builds acpuclock-8226.txt. but rename to acpuclock-8226.c and replace in:/kernel/arch/arm/mach-msm/ before compiling kernel? A custom ROM without overclock doesn't make sense to me--especially CyanogenMod, right? This file defines freqs up to 1.6GHz. The freqs just have to be defined in this file to be used in SetCPU Root, etc., or likely the performance settings in CM12 too, but the latter may also be affected by an additional config file, dunno. This CPU config file is from the Moto G2 FalconExperience OC kernel for the exact same CPU as ours (link to source file was in my OC thread), so we know these defined frequencies absolutely work for our particular CPU. But, we could always add more if 1.6GHz wasn't high enough.... Thanks in advance! :)
Just so everyone knows, there's an option called "Expanded Desktop" in the Display settings that can hide the navigation bar and/or the status bar. You can still slide up from the bottom of the screen to get them back. It does mess up the display of some apps, but it's better than a persistant navigation bar on a phone that doesn't need one.
Great work devs!
Edit: Hiding only the navigation bar doesn't seem to mess up the display. Hiding the status bar does.
I thought this ROM was the only one being built with over clock potential. Someone had said that in another thread. Were they wrong? No oc? Haven't flashed yet, really attached to my xposed theming, but I will be switching to this soon! How's the battery life and charging, anyone? Can you charge the phone with three power off, for faster charging? Cm11 causes the phone to reboot and lose touch sensitivity if you try, really hate that..
Flashed the new boot.img and this is what I've noticed...
- rear camera is working
- flash is not working with camera, but is working with torch app
- camcorder says its recording but does not save video
- vibration now works
- a few times now when trying to wake the screen it will be unresponsive... Holding the power button to force reboot or pulling battery is only thing I can do
I have installed a few themes and played with several settings so I could be the reason screen becomes unresponsive so I may try a fresh install to see if anything changes
All in all running good!!
:D:cool::D:cool:
:D:cool::D:cool:
Camera flash does work. Just can't force it on, seems to react to the light? Sensor on the front of the phone...
My screen unresponsiveness has not shown up again since changing back to the stock theme
:D:cool::D:cool:
Thank you for trying this out for everyone and letting us know how it works!
However, I have one question,
Does your charging still work? The OP hints that it may not after flashing the other boot.img.
:D:cool::D:cool:
:D:cool::D:cool:
Did you flash this with flashify?
Funny you should ask, was just about to post..I thought charging was working as the battery icon in the notification bar shows a lightning bolt...however when I go to battery in settings it says "not charging"
So no I don't think it is working...
Edit:
Tried hooking USB to my work PC and I get the same results... Also my PC is not recognizing my phone.. I do get a notification for adb on my phone but that is all
Almost everything seems to work fine. Except now it keeps crashing and gets stuck on a black screen until I hard reset it (probably due to something I've done on xposed) awesome job dude!
I was talking about the other CM12...
http://androidforums.com/index.php?posts/6835345
Question: is this stable enough for bare minimums? All I need are texting (Google Messenger or EvolveSMS if former won't work), calling, web browsing, and data tether.
Don't need camera, not going to run many apps, no games at all.
