Relyt2012
I have a zte zmax z970 metropcs, I then flashed cm13 beta 2. Qfterbthat I was able to actually get LTE however I recommend using broken os 4.9 (6.0.1) just look through the form under (brokenos landfill the oddballs) look draconis
Other than that I suggest if you must use cm13 reflash it!
