Help CM13 upgrade issues for S3 ATT i747
Does the stock software contain a stock recovery? It has bee a while since I ran the original software and cannot remember.
If you are getting the NJ2 stock rooted from the XDA link then no. He has a separate zip for the stock recovery.
So If I flash this one, I should be able to get into recovery? After that is successfully done, should I try and flash the cm13 after this?
I'm thinking if you get stock NJ2 working correctly, with known baseband and your IMEI info correct, you should be able to flash CM13 again without the baseband unknown issue.
Didn't ask before, but are you getting CM13 from CM website or other?
You should only need to flash the stock recovery zip and do factory reset in stock recovery if it hangs on AT&T logo for more than 10 min at boot.
