hi guys
just wondering if anyone else is having the same annoying problem with cm7.0.3.
every so often (usually after i finish writing a text message with standard app) the bottom menu including the dialler and Internet icon completely disappear! means i need to reboot to get them back. its happened half a dozen times over the past few weeks now.
Very tempted to try out a different rom if it keeps happening. really like cm7 but seeing as i only rooted 2 months ago, i should really experiment with other roms before settling. may go for leedroid or android revolution next.
