Root cm7 music edition help
dhruvbatra205
i want the stock contact apps so i can do the syncing with accounts...and my market turns on...says that you need to add at least one google account...i press yes to add an account...the market closes, and nothing opens!
help pls!
help pls!
I guess your problem is already solved.. Though to add a account go to Settings>>Account and Sync>>Google and then follow the onscreen dialogs to complete adding a Google account and then run market... :)
Or, restore your previous CM7 backup and then flash Music Edition. Wipe cache only. DOn't wipe data and reboot. It will take time 10-20 minutes to boot then you will get new CM7 with your old apps and data intact... :)
