Root CM7 Project for LG Ignite AS855
Build enviroment got hosed up for some reason. Wiped everything out and started from scratch. Now I can't get any project to even start building. Keep getting "brunch: command not found" not matter what I do. I don't see the function brunch() in envsetup.sh. About ready to throw in the towel.
Well, I've put a hold on building from source and tried my luck at porting the LG Black P970's CM7 to the Ignite.
Finally got it to boot into the home screen. However:
No sound. (ALSA Module not found!!!)
Wifi can see networks but reboots when trying to connect.
With wifi off it rarely reboots.
USB works, mounts SD Card, adb works.
Camera locks up when you take a pick.
Phone doesn't work - Anyone know of all the radio files that need to be inplace? The Black is GSM and Ignite is CDMA.
Now to dig thru logcat output to see what I can find.
@Playful
Ok, I commented out:
BOARD_CAMERA_LIBRARIES := libcamera
The camera libs and wpa_supplicant files are pulled from phone, the setup-makefiles.sh is updated and builds ignite-vendor-blobs.mk like it should.
Is the above what you meant when you say use the camera libs and wpa_suppilcant from the stock rom?
I notice this at the very start of the build. Not sure if this is right or not.
Code:
build/core/Makefile:32: warning: overriding commands for target `out/target/product/ignite/system/lib/hw/lights.omap3.so'
build/core/base_rules.mk:474: warning: ignoring old commands for target `out/target/product/ignite/system/lib/hw/lights.omap3.so'
build/core/Makefile:32: warning: overriding commands for target `out/target/product/ignite/system/bin/rild'
build/core/base_rules.mk:474: warning: ignoring old commands for target `out/target/product/ignite/system/bin/rild'
build/core/Makefile:32: warning: overriding commands for target `out/target/product/ignite/system/lib/libril.so'
build/core/base_rules.mk:474: warning: ignoring old commands for target `out/target/product/ignite/system/lib/libril.so'
build/core/Makefile:32: warning: overriding commands for target `out/target/product/ignite/system/bin/wpa_supplicant'
build/core/base_rules.mk:474: warning: ignoring old commands for target `out/target/product/ignite/system/bin/wpa_supplicant'
build/core/Makefile:32: warning: overriding commands for target `out/target/product/ignite/obj/lib/libcamera.so'
build/core/dynamic_binary.mk:141: warning: ignoring old commands for target `out/target/product/ignite/obj/lib/libcamera.so'
build/core/Makefile:32: warning: overriding commands for target `out/target/product/ignite/system/lib/libcamera.so'
build/core/base_rules.mk:474: warning: ignoring old commands for target `out/target/product/ignite/system/lib/libcamera.so'
Here's the error it stops on now:
Code:
make: *** No rule to make target `out/target/product/ignite/obj/lib/libicapture.so', needed by `out/target/product/ignite/obj/SHARED_LIBRARIES/libcamera_intermediates/LINKED/libcamera.so'.  Stop.
Edit: I believe I figured this out.:D
Now I'm back at the same error/errors prior to the changes above. Don't think I actually did what you asked.:confused:
Code:
make: *** [out/target/product/ignite/obj/SHARED_LIBRARIES/libcamera_intermediates/CameraHal.o] Error 1
make: *** Waiting for unfinished jobs....
hardware/ti/omap3/camera-omap3/CameraHal_Utils.cpp:1201: error: 'IPP_ProcessImage' was not declared in this scope
hardware/ti/omap3/camera-omap3/CameraHal_Utils.cpp:1208: error: 'struct android::OMX_IPP' has no member named 'hIPP'
hardware/ti/omap3/camera-omap3/CameraHal_Utils.cpp:1208: error: 'IPP_StopProcessing' was not declared in this scope
make: *** [out/target/product/ignite/obj/SHARED_LIBRARIES/libcamera_intermediates/CameraHal_Utils.o] Error 1
Update. Got it to build from sources now and boots fine. Wifi is now working! Still no audio or bluetooth. Camera FC's. I guess that's progress.:D
Ok now have audio working. Getting constant sensor errors. Still can't get Phone to work. Anyone have any ideas on what to check to get phone working?
