samrox144 Android Expert Oct 24, 2011 #1 how to install 1-copy to sd card 2-take back up 3-flash zip file and reboot this gives you setting menu of cm7 Attachments CMSettings.zip CMSettings.zip 2.3 MB · Views: 58
A aptsanju Member Oct 24, 2011 #2 this is not working... it installs fine but it is not booting over... it goes to black screen and no functions...
insane_subro Well-Known Member Oct 25, 2011 #4 samrox144 said: how to install 1-copy to sd card 2-take back up 3-flash zip file and reboot this gives you setting menu of cm7 Click to expand... how come The ROM has to be coded to support all the options in there, otherwise you will probably just end up with a bunch of force closes.
samrox144 Android Expert Oct 25, 2011 #5 this contains only some of features not all of them...they may work on custom rom
