Root Cm7 user here, need help
tythunder
Hello all, currently I'm running cm7 rom. I've been on this rom for a while now and want to try something new. My kernel is imsoyen(so?) 5.1.0aosp. Both my radios end in 906w I believe.
The rom I want to try is this: http://forums.infectedrom.com/showthread.php/1757-%C3%A2%C2%98%C2%85-%C3%A2%C2%98%C2%86-ROM-NuSenseROM-ICS-Sense-3-6-XLoud-Beta-%C3%A2%C2%98%C2%86-%C3%A2%C2%98%C2%85?p=53835#post53835
It's been a while since I flashed a rom but I'm pretty sure I remember. But don't I need to switch radios for this to work? If so what order do I need to flash, rom then radio, right?
Without doing any research on that ROM, either download a couple radio versions or stay in an area with wifi, make a backup before you flash, and then go at it. You'll see right away if the radio isn't compatible (you won't get any signal) and then you just need to go back to recovery and flash another radio.
Let us know what radios you end up using and how battery life is. My experience has been that the ICS ROMs have horrible battery life. :(
I tried Liquid ICS with the .19 radio and was getting maybe 4 hours with the Rezound battery. I flashed back to Skyraider Zeus and get 8+ hours with the same usage.
I'd previously tried the BAMF leak with the updated radios and was getting around 3 hours.
If anyone's running an ICS ROM and gets decent battery life I'd be very interested to know.
I'm on Infected ROMs NuSense, using the .9 radio. I unplug around 7 in the morning, plug back in around 8 or 9 at night with moderate use. You will need to flash an ICS radio if you're running an ICS ROM.
Ok I just downloaded the NuSenseROM. And I see where it says recommended radio, but it's .19 not .9. Where do I get the .9 radio? Second, in what order should I flash this rom and radio?
Ok tried NuSenseROM again. It seems like it would be a nice rom. It's just too laggy and finicky for me. I got force closes a lot to. So now I'm back on cm7. Question though. My current radios are 906w (5th gb leak) what can I upgrade to that's compatible with cm7? Keep the ICS radios? I ask cuz I saw my 4g working on cm7 using the ICS leaked radios
Sent using Tapatalk, stay thirsty my friends.
Does the video camera work? What about Netflix?
By .9 radio are you referring to 605.9? I can't remember what the 'official' ICS radio leak version is...
If the video and Netflix work I may have to check out this ROM..
