nekogarushia
CM9 (ICS) For the LG Vortex has reached Beta! You can find out more here! http://forums.androidcentral.com/lg-vortex/186116-rom-beta-quattrimus-ics.html
Credits
Quattrimus is the product of some amazing work by many people. First and foremost:
lupohirp and "team HAL" for doing the impossible: building the first ICS ROM for the LG P500.
drewwalton19216801 for porting lupohirp's ROM to the Optimus S.
thekraven for lots of help in finding and sharing patches.
The CyanogenMod and AOKP teams for all their work on fixing and improving Android.
blarf for creating IHO.
LeslieAnn for the awesome build server.
Many, many others.
Status
Beta test. Everything is working to some degree and most things are fully functional.
Known issues:
Deep sleep is not entered often/reliably, increasing battery drain.
Bluetooth disconnect can cause reboots.
Tethering is not functional. Workaround: use barnacle wifi tether.
Camcorder videos will not play. Workaround: use mx player.
HQ video (eg. youtube) is choppy. No workaround.
Device specific issues for the VS660:
Low mic volume.
Roaming indicator always shown.
Screen rotation does not work.
Credits
Many, many others.
Status
Known issues:
Low mic volume.
